This procedure does not apply to VSP 8600 Series and XA1400 Series.
Perform this procedure to display the Auto-sense configuration on the switch.
show auto-sense [access-differv] [data] [dhcp-detection] [eapol] [fa] [isis] [onboarding] [qos] [voice] [wait-interval]
show interfaces gigabitEthernet auto-sense [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
Display the Auto-sense configuration related to voice:
Switch:1>show auto-sense voice
                              AUTO-SENSE VOICE Config
TYPE   LDDP-AUTH ENABLE I-SID      C-VID      DSCP       PRIORITY
phone  FALSE            2000       2000       46         6
1 out of 1 Total Num of AUTO-SENSE entries displayed
            Display the Auto-sense status and state on a range of ports:
Switch:1>show interfaces gigabitethernet auto-sense 1/1-1/5
                                Port Auto-sense
PORT     AUTO-SENSE   AUTO-SENSE            AUTO-SENSE
NUM      STATUS       STATE                 PORT-DATA-ISID
1/1      Enable       UNI-ONBOARDING        500
1/2      Disable      OFF
1/3      Disable      OFF
1/4      Disable      OFF
1/5      Disable      OFF
            Display the Auto-sense status for Fabric Attach (FA):
Switch:1>show auto-sense fa
                                   AUTO-SENSE FA Config
MSG-AUTH                       MSG-AUTH-KEY
enabled                        ****
                           AUTO-SENSE FA Client specific config
TYPE                EAPOL STATUS    I-SID   VLANID  C-VID  MGMT I-SID MGMT C-VID
camera              Auto            100     100    untag   -          -
wap-type1           Auto            200     200    untag   -          -
open-virtual-switch Auto            -       -      -       -          -
proxy-no-auth       Auth            300     300    untag   -          -
proxy               Auth            400     n/a    400     400        400
 6 out of 6 Total Num of AUTO-SENSE entries displayed
            Display the Auto-sense wait-interval information.
Switch:1>show auto-sense wait-interval
                                 AUTO-SENSE GLOBAL Config
WAIT
INTERVAL
50
0 out of 0 Total Num of AUTO-SENSE entries displayed
