Delete a RIP In or Out policy when you no longer want the switch to learn a route on a specified interface or advertise a route from the routing table on a specified interface.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  1. In the navigation pane, expand Configuration > IP.
  2. Select Policy.
  3. Select the RIP In/Out Policy tab.
  4. In the desired row, double-click the InPolicy or OutPolicy column for the policy you want to delete.
  5. In the InPolicy or OutPolicy dialog box, press CTRL and then, select the policy you want to delete.
  6. Select OK.
  7. Select Apply.
