View fan tray information to see manufacturing information about the fans.
This procedure does not apply to XA1400 Series.
- On the Device Physical View, select the Device.
 - Select Chassis.
 - Select the Fan Tray Info tab.
Fan Tray Info field descriptions
Use the data in the following table to use the Fan Tray Info tab.
 Name  |
 Description  |
                                 TrayId Note: Exception: Only
                                    supported on VSP 8600
					Series.
                                 Specifies the fan tray ID.  |
                                 Description  |
                                 Shows a description of the fan tray.  |
                                 SerialNumber Note: Exception: Only
					Series.
                                 Shows the serial number for the fan tray.  |
                                 PartNumber Note: Exception: Only
					Series.
                                 Shows the part number for the fan tray.  |
                                 FlowType  |
                                 Specifies whether the air flow is front-to-back or back-to-front.  |
