Display the amount of memory used, memory available, and the number of files for internal flash memory.
 - Select File System.
 - Select the Storage usage tab.
Storage Usage Field Descriptions
Use the data in the following table to use the Storage Usage tab.
 Name  |
 Description  |
 IntflashBytesUsed  |
 Specifies the number of bytes used in internal flash memory.  |
 IntflashBytesFree  |
 Specifies the number of bytes available for use in internal flash memory.  |
 IntflashNumFiles  |
 Specifies the number of files in internal flash memory.  |
 UsbBytesUsed  |
 Specifies the number of bytes used in USB device.  |
 UsbBytesFree  |
 Specifies the number of bytes available for use in USB device.  |
 UsbNumFiles  |
 Specifies the number of files in USB device.  |
