Use the following procedure to display multiple host session information for a port.
- In the navigation pane, expand Configuration --> Security --> Data Path.
 - Click 802.1X – EAPOL.
 - Click the MultiHost Session tab.
MultiHost Session Field Descriptions
The following table describes values on the MultiHost Session tab.
 Name  |
 Description  |
 StatsPortNumber  |
 Indicates the port number associated with this port.  |
 StatsClientMACAddr  |
 Indicates the MAC address of the client.  |
 Id  |
 Indicates the unique identifier for the session.  |
 AuthenticMethod  |
 Indicates the authentication method used to establish the session.  |
 Time  |
 Indicates the elapsed time of the session.  |
 TerminateCause  |
 Indicates the cause of the session termination.  |
 UserName  |
 Indicates the user name that represents the identity of the supplicant PAE.  |
