Configure up to 10 NTP authentication keys to use MD5 or SHA1 authentication.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ntp authentication-key 5 type md5
Enter the NTP secret key: ******
Reenter the NTP secret key: ******
Switch:1(config)#ntp server 192.0.2.187 auth-enable
Switch:1(config)#ntp server 192.0.2.187 authentication-key 5
Switch:1(config)#show ntp key
                 NTP Key
Key_Id            Type
5                 MD5
10                SHA1
20                MD5
30                SHA1
100               MD5
The following table defines parameters for the ntp and ntp server commands.
                                                   Variable  |
                                                   Value  |
                                                   auth-enable  |
                                                   Activates MD5 or SHA1 authentication on this NTP server. The default is no authentication. To set this option to the default value, use the default operator with the command.  |
                                                   authentication-key <0-65534>  |
                                                   Specifies the key ID value used to generate the MD5 or SHA1 digest for the NTPv4 server. The default value is 0, which indicates disabled authentication. To set this option to the default value, use the default operator with the command.  |
                                                   type <md5|sha1>  |
                                                   Specifies the type of authentication, whether MD5 or SHA1. The default is MD5 authentication.  |
                                                   WORD<0–255>  |
                                                   Specifies the IPv4 or IPv6 address of the server.  |
