Configure RADIUS SNMP parameters for authentication and session times.
 - Click RADIUS.
 - Select the RADIUS SNMP tab.
 - Select the Enable check box to enable RADIUS SNMP.
 - In the AbortSessionTimer field, enter the period after which the session expires in seconds.
 - In the ReAuthenticateTimer field, enter the period of time the system waits before reauthenticating in seconds.
 - Select the AcctEnable check box to enable RADIUS accounting for SNMP.
 - In the UserName field, type the RADIUS SNMP user name.
 - Click Apply.
RADIUS SNMP field descriptions
Use the data in the following table to use the RADIUS SNMP tab.
 Name  |
 Description  |
 Enable  |
 Enables or disables timer authentication on the server. The default is true.  |
 AbortSessionTImer  |
 Specifies the allowable time, in seconds, before aborting the RADIUS SNMP server session (30 to 65535). The default is 180.  |
 ReAuthenticateTimer  |
 Specifies the time, in seconds, between reauthentications of the RADIUS SNMP server (30 to 65535). The default is 180.  |
 AcctEnable  |
 Enables or disables the RADIUS SNMP session timer.  |
 UserName  |
 Specifies the user name for the RADIUS SNMP accounting.  |
