This procedure does not apply to XA1400 Series and VSP 8600 Series.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
Perform this procedure to configure the IP SPB Multicast Policy on the switch.
This functionality is not supported on IGMP snooping and DvR Leaf.
Multi-area SPB boundary nodes with remote IS-IS enabled do not support IP SPB Multicast Policy .
