This procedure does not apply to VSP 8600 Series or XA1400 Series.
Use this task to view IPv6 address statistics for a Segmented Management Instance.
 - Select Mgmt Instance.
 - Select Stats.
 - Select the IPv6 tab.
 - To clear IP statistics, select Clear Stats.
 - To clear IP counters, select Clear Counters.
IPv6 Field Descriptions
Use the data in the following table to use the IPv6 tab.
                 Name  |
                 Description  |
                 InReceives  |
                 Shows the inbound packet statistics.  |
                 InHdrErrors  |
                 Shows the inbound packets with header errors statistics.  |
                 InAddrErrors  |
                 Shows the inbound packets with address errors statistics.  |
                 InUnknownProtos  |
                 Shows the inbound packets with unknown protocols statistics.  |
                 InDiscards  |
                 Shows the inbound packets discarded statistics.  |
| InDelivers |
                 Shows the inbound packets delivered statistics.  |
| InTooBigErrors | Shows the inboud packets too big errors statistics. |
| InNoRoutes | Shows the inbound packets with no routes statistics. |
| InTruncatedPkts | Shows the inbound packets truncated statistics. |
| InMcastPkts | Shows the inbound multicast packets statistics. |
| InOctets | Shows the inbound octets statistics. |
| InMcastOctets | Shows the inbound multicast octets statistics. |
| InBcastOctets | Shows the inbound broadcast octets statistics |
| InNoECTPkts | Shows the inbound packets with no Explicit Congestion Notification (ECN) statistics. |
| InECT1Pkts | Shows the inbound packets with ECT(1) statistics. |
| InECT0Pkts | Shows the inbound packets with ECT(0) statistics. |
| InCEPkts | Shows the inbound packets with Congestion Ecountered (CE) statistics. |
| OutRequests |
                 Shows the outbound packet requests statistics.  |
| OutDiscards |
                 Shows the outbound packets discarded statistics.  |
| OutNoRoutes |
                 Shows the outbound packets with no routes statistics.  |
| OutForwDatagrams |
                 Shows the forwarded datagram packets statistics.  |
| OutMcastPkts | Shows the outbound multicast packets statistics. |
| OutOctets | Shows the outbound octets statistics. |
| OutMcastOctets | Shows the outbound multicast octets statistics. |
| OutBcastOctets | Shows the outpound broadcast octets statistics. |
| ReasmTimeout |
                 Shows the packet reassembly timeouts statistics.  |
| ReasmReqds |
                 Shows the packet reassembly requests statistics.  |
| ReasmOKs |
                 Shows the successfully reassembled packets statistics.  |
| ReasmFails |
                 Shows the failed reassembled packets statistics.  |
| FragOKs |
                 Shows the successfully fragmented packets statistics.  |
| FragFails |
                 Shows the failed fragmented packets statistics.  |
| FragCreates |
                 Shows the fragments created statistics.  |
