BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
BFD provides a failure-detection mechanism between two systems. Use the following procedure to enable BFD globally.
Enabling BFD globally does not establish a BFD session. To establish a BFD session, you must enable BFD at the interface level and at the application level.Procedure
 - Select BFD.
 - Select the Globals tab.
 - In AdminStatus, select enabled.
 - Optional: Select TrapEnabled to send BFD traps.
 - Select Apply.
BFD Globals Field Descriptions
Use the data in the following table to use the Globals tab.
| Name | Description |
                                 AdminStatus  |
                                 Specifies whether BFD is enabled.  |
                                 VersionNumber  |
                                 Specifies the current version number of the BFD protocol.  |
                                 TrapEnabled  |
                                 Specifies whether BFD traps are sent.  |
