View a tunnel for IPv6 addresses.
You can assign an IPv6 address to a VLAN or brouter port.
To create MLT and LAG interfaces with IPv6, you must configure VLAN-based connections and you cannot use brouter ports.
You can also assign an IPv6 address through the navigation path, and through the navigation path.
- In the navigation pane, expand the following folders: .
 - Click Tunnel.
 - Click the Tunnel Config tab.
 - Click IPv6 Address.
Tunnel Config field descriptions
Use the data in the following table to use the Tunnel Config tab.
 Name  |
 Description  |
 AddressType  |
 Shows the address type over which the tunnel encapsulates packets.  |
 LocalAddress  |
 Configures the address of the local endpoint of the tunnel.  |
 RemoteAddress  |
 Configures the address of the remote endpoint of the tunnel.  |
 EncapsMethod  |
 Configures the tunnel mode, which is manual for manually configured tunnels.  |
 ID  |
 Configures the ID for the tunnel.  |
 IfIndex  |
 Shows the value of ifIndex that corresponds to the tunnel interface. A value of 0 indicates that the interface index has not yet been assigned. The system displays this field only on the Tunnel Config tab.  |
