Use the following procedure to clear Internet Protocol Security (IPSec) system statistics counters and view IPSec statistics on an interface. The device only clears system statistics counters on system reboot.
View IPSec statistics. Output is partial due to length.
Switch:1>show ipsec statistics system
                            IPSEC Global Statistics
InSuccesses          = 0
InSPViolations       = 0
InNotEnoughMemories  = 0
InAHESPReplays       = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
OutNotEnoughMemories = 0
generalError         = 0
InAHSuccesses        = 0
InESPSuccesses       = 0
OutAHSuccesses       = 0
OutESPSuccesses      = 0
OutKBytes            = 0
OutBytes             = 0
InKBytes             = 0
InBytes              = 0
--More-- (q = quit)
Switch:1>show ipsec statistics gigabitethernet 1/13
                              Ipsec  Port  Stats
Ifindex              = 204
InSuccesses          = 0
InSPViolations       = 0
InAHESPReplays       = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
generalError         = 0
Switch:1>show ipsec statistics vlan 1
                               Ipsec  Vlan  Stats
Ifindex              = 2049
InSuccesses          = 0
InSPViolations       = 0
InAHESPReplays       = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
generalError         = 0
                  View IPSec statistics for a loopback interface:
Switch:1>show ipsec statistics loopback 1
                             Ipsec  LoopBack  Stats
Ifindex              = 1344
InSuccesses          = 0
InSPViolations       = 0
InAHESPReplays       = 0
InESPReplays         = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
generalError         = 0
                  Switch:1>show ipsec statistics mgmtethernet mgmt
                              Ipsec  Port  Stats
Ifindex              = 64
InSuccesses          = 0
InSPViolations       = 0
InAHESPReplays       = 0
InESPReplays         = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
generalError         = 0
                  Switch:1>show ipsec statistics mgmtethernet mgmt2
                              Ipsec  Port  Stats
Ifindex              = 128
InSuccesses          = 0
InSPViolations       = 0
InAHESPReplays       = 0
InESPReplays         = 0
InAHFailures         = 0
InESPFailures        = 0
OutSuccesses         = 0
OutSPViolations      = 0
generalError         = 0
Use the data in the following table to use the show ipsec statistics command.
                                 Variable  |
                                 Value  |
                                 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                                 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
                                 loopback <1–256>  |
                                 Identifies the loopback interface.  |
                                 mgmtethernet < mgmt | mgmt2> Note:
                            Exception: only supported on VSP 8600 Series.  |
                                 Identifies the interface as the management interface.  |
                                 system  |
                                 Shows statistics for the entire system.  |
                                 vlan <1-4059>  |
                                 Specifies the VLAN.  |
