Use the following procedure to determine the data stream learned when IP multicast is configured on the VLAN.
 - Click the Routes tab.
Routes field descriptions
Use the data in the following table to use the Routes tab.
 Name  |
 Description  |
 Group  |
 Displays the IP multicast group address for this entry that contains multicast routing information.  |
 Source  |
 Displays the network address that, when combined with the corresponding route SourceMask value, identifies the source that contains multicast routing information.  |
 SourceMask  |
 Displays the network mask that, when combined with the corresponding route Source value, identifies the multicast source.  |
 UpstreamNeighbor  |
 Shows the address of the upstream neighbor from which the IP datagrams from these sources are received. The address is 0.0.0.0 if the network is local.  |
 Interface  |
 Displays the interface, slot and portnumber, or VLAN ID where IP datagrams sent by these multicast sourcesto this multicast address are received.  |
 ExpiryTime  |
 Displays the amount of time that remains before this entry ages out. The value 0 indicates that the entry is not subject to aging.  |
 Protocol  |
 Displays the protocol as one of the following:
