Configure a queue profile to apply the configured egress queue parameters to queues and ports. You must apply the profile before the changes take effect.
The switch supports six queue profiles. The default queue profile, with the name default and ID 1, is automatically created during system startup and cannot be deleted.
- In the navigation pane, expand the following folders: .
 - Click Queue Profile.
 - Click the Queue Profile tab.
 - Click Insert.
 - In the Id field, type the queue profile value.
 - In the Name field, specify a name for the queue profile.
 - To add a port to this queue, click the PortList ellipsis (...), choose a port or ports, and the click Ok.
 - Select the Apply check box.
 - Click Insert.
Queue Profile field descriptions
Use the data in the following table to use the Queue Profile tab.
 Field  |
 Description  |
 Id  |
 Specifies the ID for the queue profile.  |
 Name  |
 Specifies the queue profile name.  |
 Apply  |
 Applies the queue profile.  |
 PortList  |
 Indicates the port members of the queue profile.  |
