This procedure does not apply to VSP 4450 Series, VSP 8600 Series, or XA1400 Series.
Perform this procedure to enable Link Layer Discovery Protocol (LLDP) voice authentication of IP phones on a port.
You cannot manually enable LLDP voice authentication on an Auto-sense-enabled port. If the system detects a phone on an Auto-sense port, then “eapol voice lldp-auth” configuration is automatically applied on the port that connects to the phone. This procedure applies to ports with Auto-sense disabled.
Enabling LLDP voice authentication on a specific port:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#eapol voice lldp-auth
The following table defines parameters for the eapol voice command.
                                 Variable  |
                                 Value  |
                                 lldp-auth  |
                                 Enables Link Layer Discovery Protocol (LLDP) voice authentication of IP phones on the selected port. By default, LLDP authentication of IP phones is disabled on the switch.  |
