Configure an IS-IS accept policy for a specific I-SID number to represent a local or remote Layer 3 VSN, which allows the system to redistribute the remote VSN to the VSN where you applied the filter. An I-SID value of 0 represents the global routing table (GRT).
If the route policy changes, you must re-apply the IS-IS accept policy, unless it was the last sequence in the configuration.
Enable IS-IS globally.
Ensure the manual area exists.
You must configure a route-map to apply.
 - Click IS-IS.
 - Click the Accept Isid tab.
 - Click Insert.
 - In the Isid field, specify the SPBM nickname.
 - Select enable in the Enable check box to enable the filter.
 - In the PolicyName field, specify the route-map name.
 - Click Insert.
Accept Isid field descriptions
Use the data in the following table to configure the Accept Isid tab.
 Name  |
 Description  |
 Isid  |
 Configures a specific I-SID number to represent a local or remote Layer 3 VSN to which the IS-IS accept policy applies. Based on the routing policy the system applies, the system redistributes the remote VSN to the VSN where you applied the filter. An I-SID value of 0 represents the global routing table (GRT).  |
 Enable  |
 Enables or disables the I-SID entry. You must enable the value to filter. The default is disabled.  |
 PolicyName  |
 Specifies the route map name. You must configure a policy earlier in a separate procedure.  |
 BackbonePolicyName  |
 Specifies the backbone route map name. You must configure a policy earlier in a separate procedure.  |
