Display DHCP-relay statistics for all interfaces to manage network performance.
Slot and port information can differ depending on hardware platform.
Switch:1>show ip dhcp-relay counters option82
                     DHCP Counters Option82 - GlobalRouter
                IP              FOUND DROP CIRC ADD  DEL  REMOTE             ADD    DEL
INTERFACE       ADDR            OP82  PKT  ID   CIRC CIRC ID                 REMID  REMID
Port 1/12                       0     0    395   0     0  00:24:7f:9d:0a:00  0      0
Vlan40                          0     0    2088  0     0  00:24:7f:9d:0a:01  0      0
Use the data in the following table to use the show ip dhcp-relay counters command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Specifies a VRF instance by the VRF name.  |
 vrfids WORD<0-512>  |
 Specifies the ID of the VRF.  |
