Use this task to configure MAC-offset for a Management VLAN instance.
Configure the MAC-offset for the Management VLAN instance:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt vlan Switch:1(mgmt:vlan)#mac-offset <0-511>
The following table defines parameters for the mgmt vlan interface.
 Variable  |
 Value  |
 mac-offset <MAC-offset>  |
                             Specifies a number by which to offset the MAC address from the chassis MAC address. This ensures that each IP address has a different MAC address. If you omit this variable, a unique MAC offset is automatically generated. Different hardware platforms support different ranges. To see which range is available on the switch, use the CLI command completion Help.  |
