Showing extended VLAN VRRP
Perform this procedure to display the extended VRRP configuration for all VLANs or a specified VLAN on the device.
Switch:1#show ip vrrp interface vlan
                                   Vlan Vrrp
VLAN VRF              VRRP IP              VIRTUAL
ID   NAME             ID   ADDRESS         MAC ADDRESS
200  GlobalRouter     17   9.9.9.42        00:00:5e:00:01:11
All 1 out of 1 Total Num of Vlan Vrrp displayed
 Variable definitions
Use the data in the following table to use the show ip vrrp interface vlan command.
 Variable  |
 Value  |
 <1-4059>  |
 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
 portList  |
 Specifies the slot or port number of a range of ports.  |
 vrf WORD<1-16>  |
 Specifies the name of the VRF.  |
 vrfids WORD<0-512>  |
 Specifies the ID of the VRF and is an integer in the range of 0–512.  |
Use the data in the following table to use the show ip vrrp interface vlan [<1-4059>] [portList] verbose [vrf WORD<1-16>] [vrfids WORD<0-512>] command output.
 Variable  |
 Value  |
 VLAN ID  |
 Indicates the VLAN ID.  |
 STATE  |
 Indicates the current state of the virtual router.
 CONTROL  |
 Indicates the virtual router function. Configure the value to enabled to transition the state of the router from initialize to backup. Configure the value to disabled to transition the router from master or backup to initialize.  |
 PRIORITY  |
 Indicates the priority for the virtual router (for example, master election) with respect to other virtual routers that are backing up one or more associated IP addresses. Higher values indicate higher priority. A priority of 0, which you cannot configure, indicates that this router ceased to participate in VRRP and a backup virtual router transitions to become a new master. Use a priority of 255 for the router that owns the associated IP addresses.  |
 MASTER IPDDR  |
 Indicates the master router real (primary) IP address. The master IP address is listed as the source in the VRRP advertisement last received by this virtual router.  |
 ADVERTISE INTERVAL  |
 Indicates the time interval, in seconds, between sending advertisement messages. Only the master router sends VRRP advertisements.  |
 CRITICAL IPADDR  |
 Indicates the IP address of the interface that causes a shutdown event.  |
 HOLDDOWN_TIME  |
 Indicates the configured time (in seconds) that the system waits before it preempts the current VRRP master.  |
 ACTION  |
 Indicates the trigger for an action on this VRRP interface. Options include none and preemptHoldDownTimer.  |
 CRITICAL IP ENABLE  |
 Indicates that a user-defined critical IP address is enabled. No indicates the use of the default IP address (0.0.0.0).  |
 BACKUP MASTER  |
 Indicates the state of designating a backup master router.  |
 BACKUP MASTER STATE  |
 Indicates the state of the backup master router.  |
 FAST ADV INTERVAL  |
 Indicates the time interval, in milliseconds, between sending Fast Advertisement messages. When the Fast Advertisement Interval is enabled, the Fast Advertisement Interval is used instead of the regular advertisement interval.  |
 FAST ADV ENABLE  |
 Indicates the Fast Advertisement Interval status.  |
