This procedure does not apply to VSP 4450 Series, VSP 8600 Series, or XA1400 Series.
  • Enable EAP globally or on the port.
    enable
    configure terminal
  2. Configure an I-SID offset value:
    eapol auto-isid-offset <0-15995903>
  3. Enable EAP globally:
    eapol enable
  4. Confirm that your configuration is correct:
    show eapol system
Configure an I-SID offset value and enable I-SID offset globally on the switch:
Switch:1> enable
Switch:1#config terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#eapol auto-isid-offset 1000
Switch:1(config)#eapol enable
View the current device configuration:
Switch:1>show eapol system
                                  Eapol System
                     eap : disabled
           Eapol Version : 3
         non-eap-pwd-fmt : mac-addr
     non-eap-pwd-fmt key : ******
 non-eap-pwd-fmt padding : disabled
 auto-isid-offset status : disabled
 auto-isid-offset value  : 1000
The following table defines parameters for the eapol auto-isid-offset command.
Variable
Value
<0-15995903>
Specifies the auto I-SID offset value.
The default is 15995903.
enable
Enables auto I-SID offset.
The default is disabled.
