This procedure only applies to VSP 7400 Series.
Perform this procedure to configure Multi-area SPB Layer 3 static I-SID routed multicast redistribution policy in the home area.
Routed multicast redistribution is available for IPv4 only. With the MAC learning disabled, the static data I-SID multicast redistribution policy takes precedence over the Layer 2 multicast redistribution.
  1. In the navigation pane, expand the Configuration > Fabric.
  2. Select MultiArea.
  3. Select the L3 MC Redist Home Static ISID List tab.
  4. Select Insert.
  5. In the Type field, select staticisid.
  6. Select Enable.
  7. In the IsidListName field, type the name of the I-SID list.
  8. In the Apply field, select apply.
  9. Select Insert.
