Use trace to observe the status of IPv6 at a certain time.
  • Confirm that trace level 99 is set to a value of 1 before you use trace to diagnose IPv6 problems. Trace level 1 is very terse.
Caution
Caution
Risk of traffic loss
Using the trace tool inappropriately can cause primary CPU lockup conditions, loss of access to thex device, loss of protocols, and service degradation.
  1. Enter Privileged EXEC mode:
    enable
  2. Activate or deactivate the trace for the IPv6 base:
    trace ipv6 base <disable|enable> <all|debug|error|icmp|info|ipclient|nbr|pkt|warn> [vrf WORD <1–16>]
  3. Activate or deactivate the trace for IPv6 forwarding:
    trace ipv6 forwarding <disable|enable> <all|debug|error|info|pkt|warn> [vrf WORD <1–16>]
  4. Activate or deactivate the trace for IPv6 neighbor discovery:
    trace ipv6 nd <disable|enable> <all|debug|error|info|nbr|pkt|redirect|warn> [vrf WORD <1–16>]
  5. Activate or deactivate the trace for IPv6 OSPF:
    trace ipv6 ospf <disable|enable> <adj|all|config|error|import|info|lsa|pkt|spf|warn> [vrf WORD <1–16>]
  6. Activate or deactivate the trace for the IPv6 routing table manager:
    trace ipv6 rtm <disable|enable> <all|change-list|debug|error|fib|info|redist|update|warn> [vrf WORD <1–16>]
  7. Activate or deactivate the trace for IPv6 transport:
    trace ipv6 transport <disable|enable> <all|common|tcp|udp> [vrf WORD <1–16>]
  8. Deactivate the trace to prevent service degradation:
    trace shutdown
    clear trace
Switch:1>enable
Activate the trace for all the IPv6 base categories on the Management Router:
Switch:1#trace ipv6 base enable all vrf MgmtRouter
Activate the trace for all the IPv6 forwarding categories:
Switch:1#trace ipv6 forwarding enable all
Activate the trace for all the IPv6 neighbor discovery categories:
Switch:1#trace ipv6 nd enable all
Activate the trace for the all IPv6 routing table manager categories:
Switch:1#trace ipv6 rtm enable all
Activate the trace for all the IPv6 transport caterories:
Switch:1#trace ipv6 transport enable all
Deactivate the trace:
Switch:1#trace shutdown
Switch:1#clear trace
Removed 5 files.
The following table defines parameters for the trace ipv6 command.
Variable
Value
Enables or disables a specific trace category for IPv6 base.
Enables or disables a specific trace category for IPv6 forwarding.
Enables or disables a specific trace category for IPv6 neighbor discovery.
Enables or disables a specific trace category for IPv6 OSPF.
Enables or disables a specific trace category for IPv6 routing table manager.
Enables or disables a specific trace category for IPv6 transport.
vrf WORD<1–16>
Specifies the VRF name.
