Use the data in the following table to use the SSD tab.
This procedure only applies to VSP 4900 Series.
Perform this procedure to display information about an installed Solid State Drive (SSD) on a switch.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Chassis.
  3. Select the SSD tab.
SSD Field Descriptions
Name Description
ProductName
Specifies Solid State Drive (SSD) product name.
VendorName
Specifies the SSD vendor.
ManufactureDate
Specifies the date on which the SSD was manufactured.
SerialNum
Specifies the SSD serial number.
PartNum
Specifies the SSD part number.
DeviceVersion
Specifies the version of the SSD.
TotalSize
Specifies the total memory size of the SSD.
