This procedure only applies to the VSP 7400 Series.
Ensure that you enable DvR globally on the node.
Perform this procedure to view the remote DvR backbone entries (redistributed host routes) learned from all Controllers in all DvR domains.
You can view DvR backbone entries only on a Controller. Viewing backbone entries does not apply to a Leaf node.
 - Select DVR Remote.
 - Select the Backbone Entries tab.
 - Optional: To filter the rows based on the specific criteria, click Filter.
Backbone Entries Field Descriptions
Use the data in the following table to use the Backbone Entries tab.
 Name  |
 Description  |
 IpAddrType  |
 Specifies the address type of the DvRbackbone host (IPv4 remote ARP).  |
 IpAddr  |
 Specifies the IPv4 address of the DvR backbone host.  |
 L3Isid  |
 Specifies the Layer 3 I-SID of the DvR backbone host.  |
 DomainId  |
 Specifies the domain ID of the DvR backbone host.  |
 EcmpIndex  |
 Specifies the ECMP index of the DvR backbone host.  |
 HostMacAddr  |
 Specifies the MAC address of DvR backbone host.  |
 L2Isid  |
 Specifies the Layer 2 I-SID of the DvR backbone host.  |
 AdvControllerName  |
 Specifies the host name of the advertising Controller.  |
 AdvController  |
 Specifies the host MAC address of the advertising Controller.  |
 NextHopName  |
 Specifies the host name of the next hop Backbone host in the DvR route.  |
 NextHopMac  |
 Specifies the MAC address of the next hop Backbone host in the DvR route.  |
