This procedure only applies to XA1400 Series.Perform this procedure to dynamically obtain the source IP address for the IPsec tunnel from DHCP when you deploy the XA1400 Series in an environment that requires more than one provider connection with IPsec.
Disable IPsec on the logical interface.
 - Ensure that the DHCP client is enabled for the Management Instance VLAN interface.
 - Ensure that there is coexistence between the VOSS routing stack and the Management Instance VLAN interface. Use the propagate-to-routing command from the mgmt VLAN level to move to the coexistence mode automatically. For more information, see VLAN.
The static source IP address for the IPsec tunnel cannot be the same as the global or dynamically configured source IP address.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#logical-intf isis 3 Switch:1(config-isis-3-198.51.100.1)#ipsec tunnel-source-address type dhcp Switch:1(config-isis-3-198.51.100.1)#ipsec
