Use the following procedure to create and configure an IKE Phase 1 profile.
 - Click IKE.
 - Click the Profile tab.
 - Click Insert.
 - In the Name field, type a profile name.
 - Complete the remaining optional configuration to customize the policy.
 - Click Insert.
IKE profile field descriptions
Use the data in the following table to use the tab.
 Name  |
 Description  |
 Name  |
 Description  |
 Name  |
 Specifies the name of the profile.  |
 HashAlgorithm  |
 Specifies the hash algorithms that can be used during IKE Phase 1 SA negotiation. The default value is sha256.  |
 EncryptionAlgorithm  |
 Specifies the encryption algorithms that can be used during IKE Phase 1 SA negotiation. The default value is aesCbc.  |
 EncryptKeyLen  |
 Specifies the key length that should be used during IKE Phase 1 SA negotiation. The default value is 128.  |
 DHGroup  |
 Specifies the Diffie-Hellman groups that can be used during IKE Phase 1 SA negotiation. The default value is mod1024.  |
 ExchangeMode  |
 Specifies the IKE Phase 1 negotiation mode. The default value is main.  |
 LifetimeSeconds  |
 Specifies the amount of time for which an IKE Phase 1 SA can remain valid during IKE Phase 1 negotiation. A value of 0 means no the SA always remains valid. The default value is 86400 seconds.  |
