The system uses the Link Layer Discovery Protocol (LLDP) Fabric Connect Type-Length-Value (TLV) to communicate B-VLANs and system IDs between nodes in the SPB cloud. For more information about LLDP and its interaction with Fabric Attach, see Link Layer Discovery Protocol (802.1AB) Fundamentals.
                             TLV Type  |
                             TLV Length  |
                             OUI  |
                             Subtype  |
                             Fabric Connect Capability  |
                             B-VLANs Number  |
                             B-VLAN-1  |
                             B-VLAN-2  |
                             System ID Length  |
                             System ID  |
                             7 bits  |
                             9 bits  |
                             3 octets  |
                             1 byte  |
                             1 byte  |
                             1 byte  |
                             2 bytes  |
                             2 bytes  |
                             1 byte  |
                             6 bytes  |
                             TLV Field  |
                             Description  |
                             OUI  |
                             Specifies the Extreme OID value (0xd88466).  |
                             Fabric Connect capability  |
                             Fabric Connect capability is enabled on all nodes that support Zero Touch Fabric Configuration. The value is 0 if the LLDP Fabric Connect TLV is not carrying any information in it. By default, the value is set to 1 on all ports.  |
                             B-VLANs number  |
                             Specifies the number of B-VLANs that the TLV can carry. The LLDP Fabric Connect TLV supports an unlimited number of B-VLANs, but Zero Touch Fabric Configuration sends two B-VLANs through the TLV. The value is 0 if the node is sending default B-VLAN values.  |
                             B-VLANs  |
                             Specifies the B-VLAN that is user-configured or dynamically learned from a neighbor node in the network.  |
                             System ID Length  |
                             Specifies the length (in bytes) of the System ID.  |
                             System ID  |
                             Specifies the IS-IS system ID.  |
