            This procedure does not apply to XA1400
					Series and VSP 8600
					Series.
            Perform this procedure to display the static data I-SID IP multicast routes
                information.
                In the navigation pane, expand .
                Select SPBM.
                Select the StaticIsidIpMcastRoutes tab.
                Select the desired row and type the value of static data I-SID.
