Use this procedure to configure the device subject parameters to identify the device. The parameters include name, Email ID, company, department, and location of the subject.
 - Select Certificate .
 - Select the Subject or Global Subject tab.
 - In the CommonName field, type the name of the subject.
 - Complete the remaining optional configuration to customize the policy.
 - Select Apply.
Subject field descriptions
Use the data in the following table to use the Subject tab.
 Name  |
 Description  |
 CommonName  |
 Specifies the name of the subject sending the Certificate Signing Request to the Certificate Authority.  |
 EmailAddress  |
 Specifies the Email address of the subject sending the Certificate Signing Request to the Certificate Authority.  |
 OrganizationalUnit  |
 Specifies the organizational unit of the subject sending the Certificate Signing Request to the Certificate Authority.  |
 Organization  |
 Specifies the organization of the subject sending the Certificate Signing Request to the Certificate Authority.  |
 Locality  |
 Specifies the locality of the subject sending the Certificate Signing Request to the Certificate Authority.  |
 Province  |
 Specifies the province of the subject sending the Certificate Signing Request to the Certificate Authority.  |
 Country  |
 Specifies the country of the subject sending the Certificate Signing Request to the Certificate Authority.  |
 InstallFile  |
 Installs the specific certificate file type obtained offline from the Certificate Authority.  |
 InstallFileName  |
 Specifies the certificate file name to install.  |
 UninstallFile  |
 Uninstalls the specific certificate file type obtained offline from the Certificate Authority.  |
 UninstallFileName  |
 Specifies the certificate file name to uninstall.  |
 GenerateCsr  |
 Generates the certificate signing request to obtain the offline subject certificate.  |
