BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
Use the following procedure to configure BFD on an IPv6 static route.
The following table defines parameters for the ipv6 route bfd command.
                             Variable  |
                             Value  |
                             WORD<0-128>  |
                             Specifies the BFD static route IPv6 address.  |
                             port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}  |
                             Specifies the port number for the BFD IPv6 static route.  |
                             vlan <1-4094>  |
                             Specifies the VLAN ID for the BFD IPv6 static route.  |
