IPFIX allows you to monitor IPv4 traffic flows. Use the following procedure to enable IPFIX globally.
The default global state is disabled.
 - Click IPFIX.
 - Click the Globals tab.
 - To enable IPFIX, click enable in the ConfState option box.
 - Optional: To configure an observation domain ID, type a value in the ObservationDomainID field.
 - Optional: To configure the aging interval, type a value in the AgingInterval field.
Use the data in the following table to use the Globals tab.
                 Name  |
                 Description  |
                 ConfState  |
                 Specifies whether IPFIX is enabled or disabled. The default is disabled.  |
                 ObservationDomainID  |
                 Specifies a value for the observation domain used to send IPFIX messages. The default is 0 (no observation domain). If the value is 0, data that is sent is not applied to a single observation domain.  |
                 AgingInterval  |
                 Specifies (in seconds) the flow record aging interval. The aging interval determines how long a traffic flow that is no longer being received is retained as a flow. The default is 40 seconds.  |
