Use the following procedure to configure a time interval, after which the key exchange takes place.
Switch:1> enable Switch:1# configure terminal
Configure the SSH rekey time-interval to 3 hours:
Switch:1(config)# ssh rekey time-interval 3
The following table defines parameters for thessh rekey time-interval command.
 Variable  |
 Value  |
 <1–6>  |
 Sets the time-interval for SSH rekeying in hours, the range is 1 to 6.  |
