Use the following procedure to display BFD configuration on an interface.
The following example displays VLAN interface configuration information for BFD.
Switch:1>show ip bfd interfaces vlan 11
                                    Vlan Bfd
VLAN       STATUS     MIN_RX     INTERVAL   MULTIPLIER      VRF-ID
11         enable     200        200        3               0
Switch:1>enable
Switch:1#show ip bfd interfaces loopback
                          Circuitless IP Interface Bfd
INTF ID    STATUS     MIN_RX     INTERVAL   MULTIPLIER      VRF-ID
2          enable     200        200        3               2
The following table defines parameters for the show ip bfd interfaces command.
                             Variable  |
                             Value  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
                             <1-4059>  |
                             Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
                             vrf WORD<1-16>  |
                             Specifies a VRF instance by VRF name.  |
                             vrfids WORD<0-512>  |
                             Specifies a VRF or range of VRFs by ID.  |
