Perform this procedure to enable MAC move protection on virtual interswitch trunk (vIST).
Enable MAC move protection on vIST:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#sys control virtual-ist mac-move-protection
Switch:1>show sys control
                            System Control Settings
                 tcp-timestamp : enable
            tcp-keepalive-time : 60
        tcp-keepalive-interval : 10
          tcp-keepalive-probes : 5
               tcp-mtu-probing : disabled
                  tcp-base-mss : 1024
           mac-move-protection : on
The following table defines parameters for the sys control virtual-ist command.
                                 Variable  |
                                 Value  |
                                 mac-move-protection  |
                                 Enable MAC move protection on vIST. The default value is disabled.  |
