Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures.
View basic OSPF statistics:
Switch:1>enable
Switch:1#show ports statistics ospf main
                                Port Stats Ospf
PORT_NUM RX_HELLO   TX_HELLO   RXDB_DESCR TXDB_DESCR RXLS_UPDATE   TXLS_UPDATE
1/3      0          0          0          0          0             0
Use the data in the following table to use the show ports statistics ospf main command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
