Enabling VLACP globally
Enable VLACP globally to detect for end-to-end failure. VLACP uses the Hello mechanism of LACP to periodically send Hello packets to ensure there is an end-to-end approach. After Hello packets are not received, the VLACP transitions to a failure state and the port is disabled.
 - Click MLT/LACP.
 - Click the VLACP Global tab.
 - Select the VlacpEnable check box.
 - Click Apply.
VLACP Global field descriptions
Use the data in the following table to use the VLACP Global tab.
 Name  |
 Description  |
 VlacpEnable  |
 Enables VLACP globally. The default is disabled.  |
