This procedure does not apply to XA1400 Series and VSP 8600 Series.
Create a VLAN. For more information see, VLAN Configuration
Use mvpn-isid to dynamically create a VRF on one of the reserved Layer 3 VSN VLANs. The dynamically created VRF, l3vsn-<isid_number>, obtains the <isid_number> from the mvpn-isid <isid_number> command.
If you are using a DvR leaf instance, the VRF name is l3vsn-<l3isid>.
You can now use the ip spb-multicast enable command on that VLAN without configuring an IP address.
If a VRF with the same I-SID already exists on the device, the VLAN is associated with the existing VRF when you enter mvpn-isid on the VLAN.
You cannot have an IP address and mvpn-isid configured on the same VLAN at the same time.
  1. Enter VLAN Interface Configuration mode:
    enable
    configure terminal
    interface vlan <1–4059>
  2. Configure an MVPN I-SID on the VLAN:
    mvpn-isid <0-15999999>[0-511]
  3. Optional: Configure a routed SPB querier source IP address:
    ip igmp routed-spb-querier-addr {A.B.C.D}
  4. Enable SPB Multicast on the VLAN:
To enable SPB Multicast for a VLAN in VRF use mvpn-isid 100.
Switch:1>enable
Switch:1#config terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#interface vlan 10
Switch:1(config-if)#mvpn-isid 100
Switch:1(config-if)#ip igmp routed-spb-querier-addr 192.0.2.1
Switch:1(config-if)#ip spb-multicast enable
The following table defines parameters for the mvpn-isid command.
Variable Definition
<0-15999999>[0-511] Specifies the I-SID. The MAC offset value is optional.
Note: Use mvpn-isid 0 to enable spb-multicast for a VLAN in the Global Routing Table.
The following table defines parameters for the ip igmp routed-spb-querier-addr command.
Variable Definition
{A.B.C.D} The SPB querier address. The default is 0.0.0.0.
