Use the following procedure to configure an IPsec policy. An IPsec policy defines the level of security for different types of traffic.
You can only configure the IPsec policies for IPv4 addresses for UDP, TCP, and ICMPv4 protocols. You can continue to configure IPsec policies for IPv6 addresses for ICMPv6, OSPFv3, TCP, and UDP.
If you downgrade your software, the current IPsec configurations are no longer supported. You must boot with the factory default settings for IPsec, and then reconfigure the IPsec features.
Create an IPsec policy named newpolicy:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ipsec policy newpolicy
The following table defines parameters for the ipsec policy command.
 Variable  |
 Value  |
 WORD<1–32>  |
 Specifies the IPsec policy name.  |
