This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure remote IS-IS interface level parameters. SPBM uses IS-IS to discover network topology, build shortest path trees between network nodes, and communicate network information in the control plane.
 - Select IS-IS Remote.
 - Select the Interfaces Level tab.
 - Configure the remote IS-IS interface level parameters.
 - Select Apply.
Interfaces Level Field Descriptions
Use the data in the following table to use the Interfaces Level tab.
 Name  |
 Description  |
 Index  |
 Specifies the identifier of the circuit, the value is unique within the remote IS-IS. The value is for SNMP Indexing purposes only and does not relate to any protocol value.  |
 Level  |
 Specifies the router type globally:
 The default value is l1.  |
 ISPriority  |
 Specifies an integer sub-range for remote IS-IS priority. The default is 64.  |
 HelloTimer  |
 Configures the level 1 hello interval. Specifies the maximum period, in milliseconds, between IS-IS Hello Packets (IIH) PDUs on multiaccess networks at this level for LANs. The value at Level1 is used as the period between Hellos on Level1/Level2 point to point circuits. Setting this value at Level 2 on an Level1/Level2 point-to-point circuit results in an error of InconsistentValue. The default value is 9000 milliseconds or 9 seconds.  |
 HelloMultiplier  |
 Configures the level 1 hello multiplier. The default value is 3 seconds.  |
 DRHelloTimer  |
 Indicates the period, in milliseconds, between Hello PDUs on multiaccess networks when this Intermediate System is the Designated Intermediate System. The default is 3.  |
