This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote I-SID forwarding database (FDB) on the switch.
To view the T-UNI I-SID FDB entries filtered on a port that is part of an MLT, you must mention the MLT ID in the option for the port.
 - Select ISID Remote.
 - Optional: Select the Filter button to filter the rows on basis of specific criteria.
FDB Field Descriptions
Use data in the following table to use the FDB tab.
 Name  |
 Description  |
 IsidId  |
 Specifies the service interface identifier (I-SID).  |
 Address  |
 Specifies the MAC address of the port assigned to the specific I-SID or C-MAC learned on the particular I-SID.  |
 Status  |
 Specifies the learning status of the associated MAC.  |
 Port  |
 Specifies the port on which the MAC is learned for the specific I-SID.  |
 PortType  |
                                                   Specifies if the MAC address is learned locally or on an NNI port from a remote destination.  |
 RemoteMacDestAddr  |
 Specifies the virtual BMAC address or system-ID of the remote destination.  |
 RemoteMacBVlanId  |
 Specifies the B-VLAN ID on which the remote destination was discovered.  |
 RemoteMacDestSysName  |
 Specifies the remote destination system name.  |
 Cvid  |
 Specifies the customer VLAN ID of the associated Switched UNI port.  |
