Configure the system flags to enable or disable flags for specific configuration settings.
System Flags Field Descriptions
Use the data in the following table to use the System Flags tab.
                                 Name  |
                                 Description  |
                                 EnableAccessPolicy  |
                                 Activates access policies. The default is disabled.  |
                                 ForceTrapSender  |
                                 Configures circuitless IP as a trap originator. The default is disabled.  |
                                 ForceIpHdrSender  |
                                 If you enable Force IP Header Sender, the system matches the IP header source address with SNMP header sender networks. The default is disabled.  |
                                 AuthSuccessTrapEnable  |
                                 Enables the system to send the authentication success trap, rcnAuthenticationSuccess. The default is disabled.  |
                                 MrouteStrLimit  |
                                 Enable or disable Mroute stream limit in system. The default is disabled.  |
                                 DataPathFaultShutdownEnable  |
                                 Enable or disable data path fault shutdown. The default is enabled.  |
                                 PingTracerouteContextType Note:
                            Exception: not supported on VSP 8600 Series.  |
                                 Configures the default context for executing ping commands and traceroute commands. The default is grt.  |
                                 UdpSrcByVirtualIpEnable  |
                                 Enables or disables virtual IP as the User Datagram Protocol (UDP) source. The default is disabled.  |
                                 ForceTopologyIpFlagEnable  |
                                 Activates or disables the flag that configures the CLIP ID as the topology IP. Values are true or false. The default is disabled.  |
                                 CircuitlessIpId  |
                                 Uses the CLIP ID as the topology IP. Enter a value from 1–256.  |
                                 HaCpu  |
                                 Activates or disables the CPU High Availability feature. If you enable or disable High Availability mode, the secondary CPU resets automatically to load settings from the saved configuration file. The default is enabled.  |
                                 MasterCPUSlot  |
                                 Specifies the slot number, either 1 or 2, for the master CPU. The default value is 1.  |
                                 EnableSavetoStandby  |
                                 Enables or disables automatic save of the configuration file to the standby CPU. The default value is enabled.  |
                                 HaCpuState  |
                                 Indicates the CPU High Availability state.
                                 HaEvent  |
                                 Indicates the High Availability event status.
                                 StandbyCpu  |
                                 Indicates the state of the standby CPU.  |
