Enable Debug Mode
Enables a TRACE on any port by prompting the selection on the console during boot up. This allows the user start trace for debugging earlier on specified port. Works on console connection only. The default is disabled.
Important
Important
Do not change this parameter unless directed by Technical Support.
    enable
    configure terminal
  2. Enable debug mode:
    boot config flags debugmode
  3. Save the changed configuration.
  4. Restart the switch.
