View the current BSR information to review the configuration.
You must disable static RP.
- In the navigation pane, expand the following folders: .
 - Click PIM.
 - Click the Current BSR tab.
Current BSR field descriptions
Use the descriptions in the following table to use the Current BSR tab.
 Name  |
 Description  |
 Address  |
 Shows the IP address of the current BSR for the local PIM domain.  |
 FragmentTag  |
 Shows a randomly generated number that distinguishes fragments that belong to different bootstrap messages. Fragments that belong to the same bootstrap message carry the same fragment tag.  |
 HashMask  |
 Shows the mask used in the hash function to map a group to one of the C-RPs from the RP set. The hashmask allows a small number of consecutive groups to always hash to the same RP.  |
 Priority  |
 Shows the priority of the current BSR. The C-BSR with the highest BSR priority and address (referred to as the preferred BSR) is elected as the BSR for the domain.  |
 BootStrapTimer  |
 Shows the bootstrap timer. After the bootstrap timer expires, the BSR sends out bootstrap messages.  |
