Use the Authenticator Configuration table to display configuration objects for the Authenticator PAE associated with each port.
  1. In the navigation pane, expand Configuration > Security > Data Path.
  2. Click 802.1X - EAPOL.
  3. Click the Authentication tab.
Authentication Field Descriptions
Use the data in the following table to use the Authentication tab.
Name Description
PortNumber
Indicates the number associated with this port.
ReAuthEnabled
Indicates the re-authentication status of an existing supplicant at the time interval specified in ReAuthPeriod. The default is false.
QuietPeriod
Indicates the time interval (in seconds) between authentication failure and the start of a new authentication.
The default is 60.
ReAuthPeriod
Indicates the time interval in seconds between successive re-authentications. The default is 3600 (1 hour ).
RetryMax
Indicates the maximum Extensible Authentication Protocol (EAP) requests sent to the supplicant before timing out the session. The default is 2.
RetryCount
Indicates the count of the number of authentication attempts.
