Use this procedure to configure optional management Link Layer Discovery Protocol (LLDP) TLVs for transmission.
LLDP TLVs for transmission are enabled by default.Procedure
Disable the port description LLDP transmission TLV:
Switch:1>enable Switch:1#config Configuring from terminal or network [terminal]? t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/2 Switch:1(config-if)#no lldp tx-tlv port-desc
Switch:1(config-if)#show lldp tx-tlv port 1/2
                     LLDP port tlvs
Port       PortDesc   SysName   SysDesc   SysCap
1/2        disabled    enabled   enabled   enabled
            Restore port description LLDP transmission TLV to the default value:
Switch:1>enable Switch:1#config Configuring from terminal or network [terminal]? t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/2 Switch:1(config-if)#default lldp tx-tlv port-desc
                     LLDP port tlvs
Port       PortDesc   SysName   SysDesc   SysCap    LocalMgmtAddr
1/2        enabled    enabled   enabled   enabled   enabled
The following table defines parameters for the lldp tx-tlv command.
 Variable  |
 Value  |
                             local-mgmt-addr  |
                             Specifies the local management address TLV. The default is enabled.  |
 port-desc  |
 Specifies the port description transmission TLV. The default is enabled.  |
 sys-cap  |
                             Specifies the system capabilities transmission TLV. The default is enabled.  |
 sys-desc  |
                             Specifies the system description transmission TLV. The default is enabled.  |
 sys-name  |
                             Specifies the system name transmission TLV. The default is enabled.  |
