Enable Jumbo frames to increase the size of Ethernet frames supported
on the chassis.
- On the Device Physical
View, select the Device.
                In the navigation pane, expand
 - Click Chassis.
 - Click the Chassis tab.
 - In MTU size, select either 1950, 9600 or 1522.
 - Click Apply.
