When you enable the rlogin flag, you must configure an access policy to specify the user name of who can access the switch. For more information about the access policy commands, see Access Policies for Services.
Rlogin is only supported on VSP 8600 Series.
Enable the remote access service to provide multiple methods of remote access.
File Transfer Protocol (FTP), Trivial File Transfer Protocol (TFTP) and Telnet server support both IPv4 and IPv6 addresses, with no difference in functionality or configuration.
Enable the access service for Telnet:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#boot config flags telnetd
The following table defines remote access parameters for the boot config flags command.
                                 Variable  |
                                 Value  |
                                 ftpd  |
                                 Activates or disables the FTP server on the switch. The default value is disabled. To enable FTP, ensure that the tftpd flag is disabled.  |
                                 rlogind Note:
                            Exception: rlogin and rsh are only supported on VSP 8600 Series.  |
                                 Activates or disables the rlogin and rsh server. The default value is disabled.  |
                                 sshd  |
                                 Activates or disables the SSHv2 server service. The default value is disabled.  |
                                 telnetd  |
                                 Activates or disables the Telnet server service. The default is disabled.  |
                                 tftpd  |
                                 Activates or disables Trivial File Transfer Protocol server service. The default value is disabled.  |
