Configure ACE IP destination address entries to have the filter look for specific destination IP addresses.
The ACL exists.
The ACE exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click ACE.
 - Select the appropriate ACE.
 - Click IP.
 - Click the Destination Address tab.
 - Click Insert.
 - Specify the operation type.
 - In the IPAddr box, enter the destination IP address.
 - Click Insert.
Destination Address field descriptions
Use the data in the following table to use the Destination Address tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.  |
 IPAddr  |
 Specifies the destination IP address.  |
 OperMask  |
 Specifies the mask value for the destination IP address.  |
