Display the authenticator statistics to manage network performance.
Use the clear-stats command to clear EAP or NEAP statistics.
Switch:1#show eapol auth-stats interface
                          Eap Authenticator Statistics
PORT  EAP   AUTH-EAP   START LOGOFF INVALID LENGTH LAST-RX    LAST-RX
      RCVD  TX         RCVD  RCVD   FRAMES  ERROR  VER        SRC
1/1   716   1074       0     0      0       0      1          18:a9:05:b1:04:ce
1/2   0     0          0     0      0       0      0          00:00:00:00:00:00
1/3   0     0          0     0      0       0      0          00:00:00:00:00:00
1/4   0     5          0     0      0       0      0          00:00:00:00:00:00
1/5   0     0          0     0      0       0      0          00:00:00:00:00:00
1/6   0     0          0     0      0       0      0          00:00:00:00:00:00
1/7   0     0          0     0      0       0      0          00:00:00:00:00:00
1/8   0     0          0     0      0       0      0          00:00:00:00:00:00
1/9   0     0          0     0      0       0      0          00:00:00:00:00:00
1/10  0     0          0     0      0       0      0          00:00:00:00:00:00
--More-- (q = quit)
Use the data in the following table to use the show eapol auth-stats interface command.
                             Variable  |
                             Value  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
