View application host statistics to see traffic statistics by application protocol for each host.
  1. To enter User EXEC mode, log on to the switch.
  2. View RMON application host statistics:
    show rmon application-host-stats WORD<1–64>
Switch:1# show rmon application-host-stats ?
  WORD<1-64>  Select one of these application protocols
              {TCP|UDP|FTP|TELNET|HTTP|RLOGIN|SSH|TFTP|SNMP|HTTPS}
Switch:1# show rmon application-host-stats FTP
                          Rmon Application Host Stats
HOSTADDR         INPKT      OUTPKT     INOCT      OUTOCT     CREATETIME
192.0.2.10        0          0          0          0          10/09/15 17:29:54
Protocol support can vary across platforms.
The following table defines parameters for the show rmon application-host-stats command.
Variable Value
WORD<1–64>
Specifies one of the following application protocols: TCP, UDP, FTP, TELNET, HTTP, rlogin, SSH, TFTP, SNMP, HTTPS.
Note:
Exception: the rlogin application is only supported on VSP 8600 Series.
RMON2 counts application packets received on any platform on which the application is not enabled or supported, before dropping them.
